NEK5
3/4 ton status
Besides needing to shim the radiator up (pull up front of rad support lip with crow bar, i think i bent it down stepping in and out of engine compartment) or bend the mounts down, I think these mounts will work
My question is, I think the rubber material (from a rubber bed mat) I`m using is too stiff. Is there something better I should be using?
If it makes you feel any better, just go to a junkyard and find some out of pretty much any vehicle that has that style of mounting.
