radiator on an s-10
87BrnRsd
Boone, North Carolina
My friend needs his radiator replaced on a newer (1998-ish) s-10 blazer. He doesnt have the cash for the dealer to do it so I offered to help. I have never worked on the newer s-10's before and I am wondering if there is anything that I need to know before we start. Radiators arent hard...but is there anything on this newer s-10 that I may not know about or may give me trouble? Thanks.
-Harrison
just the oil cooler lines, they have a little spring clip holding them in, other than that, it should be pretty straight forward.
Also, if there is Dex cool coolant in there, DO NOT MIX it wiht regular. Get a coolant that is compatible wiht both (certain prestones i think, it will say) and its pretty foolproof.
87BrnRsd said:
Thanks for the help. Whats the trick to the spring pins?
-Harrison
a pick or a screwdriver. There is a special tool that doesn't require removing them but its $100 through Mac. Local dealer should have a few of the clips in stock if you break, distort(I almost always distort them), or lose some.
