Anyone ever tried repairing a leak/hole in a radiator? I've had a nice 4 row installed forever, went for a test drive with an unknown passenger (screwdriver on the radiator support). That mf'er fell off, into the fan, which directed it into the radiator and broke my shroud at the bottom. I stitched the shroud back together with safety wire and was able to pickup a used 3 row for $25. Works fine, size-wise it's OK, but the mounting bracket up top is too wide for it, holds, but not firmly held.
Amazon has those flux-core aluminum and brass rods, I thought I might give it a try as I'd like to save the 4-core. Radiator shops that do that seem to be vanishing.
Charlie
Charlie
