No it's stock. This is where they were when I got it. I guess I can move then over. Not sure why previous owners drilled 2 new holes I was wondering when I put it back together.!st thing you hold down is not in the correct place. It is actually going to end up wider. Those clamps need to be over the tank/core seam. Has radiator been up sized ?
Yes its got the upward bend on the lower hose spoutIt looks like you have standard radiator brackets with a heavy duty (4 row) radiator.
If it is a radiator intended for a '67 to '72, the lower neck, (outlet) will have an upward bend so that the hose doesn't run into the frame rail. It also larger than later trucks.
'73 and up have a straight lower neck, and the lower hose has a bell at the water pump to reduce the size down for the radiator neck.
So maybe you just need the proper clamps for the thicker radiator. They are being reproduced.Yes its got the upward bend on the lower hose spout
upside down ??
I don't see anywhere for those screws to go in though on the bottom?yep shroud was upside down in the pic and those brackets are what you need from classic industries.
