Radiator size 17" or 19"
fwc
Northern Virginia
I have a 91 Jimmy (auto, a/c) that needs a new radiator. The truck also has the factory "heavy duty trailering special equipment" package.
GM dealer came up with two part numbers:
52481619 radiator core size 28 3/8"x19 3/16"x1 7/16"
52479539 radiator core size, 28 5/16"x16 7/8"x1 1/4"
Local parts store also lists a 17" and a 19" radiator. They asked me if I had "heavy duty cooling" and I wasn't sure but I assume I do with the tow package. My truck is an hour away so I can't measure right now. Anybody know for sure? :confused: :confused: I would like to pick up the radiator on my way out tomorrow
You should have the tall radiator . Without measuring , the way to tell is the mounts on the radiator support . Over the top is tall , below the top is short .
the 2 clamps that hold the radiator to the core suport are on top of the support for tall. or thay are on the back side towards the fan of the engine. as the rad is shorter . if needed just measure the highth of the center section of the rad. but with all the info on the rig you listed its going to be the tall unit.
Thanks for the explanation. I found this post which seems to explain it as well
http://coloradok5.com/forums/showthread.php?t=123950
Strange thing is, when I gave the GM dealer the VIN they gave me the part number for the 17" (16 7/8)
Now I just need to go look at the truck to make sure its a 19"
The local parts store stocks Visteon radiators, they said it was a single core aluminum with plastic side tanks. Any comments on the quality of this? How about GoDan brand?
best look at what you got. also if the fan shroud is level with the rad support its tall. and if below rad support its short. easy swap to big if you want. just need the upper bracket tabs and fan shroud from tall setup.
Just called my pops and had him take a look. Seems like its the tall 19". He said that the radiator top brackets bolt down into the support from the top and come back to hold the top of the radiator, kind of like this
front___/--------bracket-------\_______back
|support|..................................|radiator|
Yup, it's 19" just did mine last weekend. Napa. 165bones. The tall is heavyduty 3core. :laugh:
Just for giggles, what does the GM dealer want for a radiator? I just bought the tall, 3-core for my '90 Suburban for $149 at Autozone, with a lifetime warranty.
Wow radiators are getting pricey. I stuffed a 4 core into my old burb a couple of years ago and it only cot around 160 bucks. If you could I would get a 4 core cause it is next to imposible to over heat with one. You will have to bend the old 19" brackets sligtly and modify the fan shroud but it can be done.
4 cores are around $200 now. But then you also have to buy new mounts and the correct shroud. A 3-core will work fine if properly maintained. Most overheating problems are caused by 20+ year old radiators that are filled with calcium deposits and other sludge.
I was looking at the mounts on my 90 today and are you sure that the mounts need to be replaced when going from a 3 core to a 4? My mounts look like they would fit a 4 ok, maybe the rubber would need to be trimmed.
Dan..
Looked at the radiator in the truck and it was a 19" tall model. Got a replacement radiator from Advance Auto for ~150 Transpro (Modine) Model 433716. I never did get a price from the local dealer although GMpartsdirect was about 190 for what they claimed was a delco radiator.
