Radiator
79cheyenne79
maryland
When I start my truck the temp goes up to 260. Then after I hit the gas for awhile the temp drops back down to 180 like it suppose too and a few times not that often once in a blue moon it will happened while Im driving. What do ya'll think it is. I just put the temp gauge in last week and I had the truck for about 1 yr. Its a 79 k20 long bed 5.7 4bbl :mad: :doah: :yikes: :confused:
If the gauge is accurate, I'd bet the thermostat is sticking.
Parts store cheapies are a coin toss if they will work brand new out of the box, a Delco thermostat is a good choice.
agreed.
Check your coolant level, i thought i had a bad t-stat awhile back, did the same thing, went to tear it down and replace it, and found it to be very low on coolant.
Found that i had a very slow, small leak from the rad hose to the intake, fixed the hose, and went ahead and replaced the t-stat,,,,,,no problems since.:D
i changed the t stat im letting the silicone dry overnight and hopefully i wont see that problem any more. I got a t-stat that is set at 160 is that cool? i think its suppose to be set at 180
Stock GM is 195*, if it doesn't stay cool with a 195*, any other temp t-stat is a bandaid for another problem.
