FlatBlackBurb
okay so i hooked up my "badass" sound system a couple weeks after i got my suburban. the 3 remaining speakers in the truck leave something to be desired but hey, good enough. i was getting a bit pissed off because every time i turned the truck off all of my presets would dissapear. every time i started it up i would have to reprogram each one. then i figured out that i blew a fuse. i quickly replaced the fuse but now i'm faced with a different problem.
after replacing the HORN/DM fuse and taking it for a short drive, i parked and turned the truck off. the radio stayed on. being optimistic i thought to myself "cool! it;s just like the new trucks where you turn the truck off but the radio stays on until the door opens!". when i opened the door i was faced with dissapointment. the radio will stay on after the truck is turned off. so will the CB. Hey at least it saves my presets and all that crap.
so my question is, is there some way im missing that i can have the battery give the radio just enough juice to stay alert but at the same time have it shut off after i turn the truck off? its annoying because the cb will do the same thing. i come back in the morning and try and start my truck and it starts to crank rediculously slow and i figured out that i left something on. any help? thanks
If it's on the red wire it will be. Put it on the yellow wire and it will only come on if the keys are in it.
