Rally wheel/trim ring question
vegasblazer90
Registered Member
Turlock, CA
I have, I believe, 15x8 rally wheels under my 90 K5. Many years ago I had a set of perfect trim rings on her. I had just moved to Vegas and went to the local Target store and when I came back out about ten minutes later somebody had stolen them. I've been running a set of dinged up 2" trim rings for all of this time.
I'm in the process of re-doing her again and would like to pick up a new set if rings. Would the 3" trim rings work with the 8" rims?
I'm thinking of ordering the ones from LMC.
Thanks!
The 3" rings look awsome on the rallye rims... i painted the centre of my rims white to match my blazer body then put the origonal centre caps on.
the beauty rings finished it of perfectly.Sorry i can not post up picks but believe me they look awsome :woot:
Are the LMC ones chrome, or stainless like OEM? If they aren't stainless, I might reconsider. That's me, I overthink everything, but aftermarket chrome stuff is usually garbage, peeling in short order.
The wheels that came with her when I bought her back in 1999 looked like twisted moose horns. I hated the way they looked so I found the rally wheels and painted the silver to match the new paint job and they looked great with the perfect trim rings.
The wheels will need reprinting soon, as will the body. But I wanted to take care of the trim rings as they will be cheap enough.
The three inch rings WILL work though, correct?
I would rather go OEM and if I can find a set I'll do that...if not then I'll get the LMC stainless versions.
Thanks for the replies.
