Can anyone see why these wont work with a 74 Jimmy?
http://www.jegs.com/i/Wysco/938/MA035RAW/10002/-1
Ok, just checked, my 71 chevy has the angled back on.drivers side.
Maybe I missed it, but why do you want to run those ramhorns? Any details about your engine now?
Are there any dyne tests out there that show more performance with the ram style over the log style?
. Thats what got me thinking about them.I looked up the ram horn manifolds in a friends Dorman catalog,they sell both styles new now--I was mistaken about the drivers side only having the angled outlet--they BOTH were angled on the 67-72 trucks,the passenger car ram hotns were a straight outlet on both sides in most applications,but some models did have a angled outlet on the drivers side also...I wasnt able to copy the part numbers down ,as my friend was in a rush to close up right after I got to his shop...but you can likely see the illustrations on Dormans web site,,,
I'd say the worst manifolds GM used on a small block were the ones on 267-305 engines in 78-84 Malibus and Caprices,they were "over" the spark plugs and very restrictive--I think they also had a strange 5 bolt mounting pattern also..probably of no use to us 4x4 guys ,but they used those on El-caminos and other G body cars..
I'd use whatever I have on hand that works when I'm building something--I don't have a lot of cash to spend to keep my trucks alive,so whatever I have gets used up or whatever I can scrounge up free or cheap is often all I have at my disposal...I think a lot of the older stuff was built better and designed better--I'd have no fears of using ram horns on a truck whether it was a 67 or an 87...[/quote]
Thanks for the info and going outof your wy to look at your buddies manuals diesel4me that is helpful and very kind.
And to your point that I bolded out above........I could not agree more. Thats what kind of led me to the ram horn idea. See the manifolds that are on my Jimmy know are both cracked and need to replaced. I will not put cheap headers on it and $500.00 plus for a good set is not in the budget, plus the engine is bone stock. So manifolds it is. So in doing research I have found that people really seem to like the ram horns on their trucks. And as far as I can tell they are cheaper than the the normal log style manifolds any way.
If you have HEI, then you can get a set of spark plug wires for a 75 corvette, they are plenty long enough to go under the ramhorn manifolds. Other than flow, I have no idea but run them on 2 of my trucks
