Rancho Lift Spring Bushings
scoutcamper
Registered Member
Chico, CA
Hey all,
This is going to be a weird question to get answered here, but ill give it a go!
I have a Rancho 4" lift kit on my 190 GMC Jimmy Full-Size, I believe it is a RS40054S kit. I am looking for the front bushings for it. I replaced the rear(shackle) bushings a few months ago with the SE-11C Skyjacker bushings as they were all I could find that would fit. Before I tear apart the front(frame) bushings and have the truck down for a week while I try to locate the correct bushing kit I was hoping someone could point me in the right direction.
The SE11C bushing was selected because of the 1.25" ID of the rear(shackle) eye on the leaf spring. Looking at the RS954 bushing kit it says that if your shackle end is 1.25" ID use the RS994 bushing kit. I cannot locate an RS994 bushing kit to purchase. Are the Frame end(front end) bushings the same between the two kits? Anyone with any advice to offer would be appreciated.
Thanks!
I put used rancho springs on my burb and they needed new bushings. I contacted ORD and they set me up with some new greaseable ones and they have worked out great.
