Random steering parts for sale
mrk5
The Sticker Guy
Moderator
Vendor
Author
Northern Colorado
High steer tie rod, painted yellow. This is 1.5" OD 1/4" wall DOM. Tubing adapters are welded to each end for 3/4" heim joints. Length of the tube is 48.125". The heims are included and they use a 3/4" bolt. $60 shipped (picture below)
Silver crossover draglink. Made with 1.5"OD, 1/4" wall DOM. 34.5" long, 4" drop. Tube adapters are welded to each end for 1ton TRE or DLE. I ran this with a TRE on the pitman end and DLE on the steering arm side. Held up fine for 4yrs+. $50 shipped (picture below)
Black crossover draglink. Made with 1.25"OD DOM. I believe it's 1/4" wall. The threads for 1ton TRE are cut directly into the ID. 35.75" long, 2.25" drop. TRE's pictured are included. $60 shipped (picture below)
You can see in the pictures above I have a clamp type mount for a PSC remote reservoir. $10 shipped if it will do anyone some use.
Misalignment spacers. (2) 7/8" tall, (4) 7/16" tall, (2) safety washers. All for 3/4" bolt. Your choice, $3ea shipped
You can also see in the picture above I have (4) nuts for D60 high steer arm studs. New, never used. $4 shipped
***SOLD***Ballistic fab tube clamp with tabs welded on. For 1.5" OD tube. Welded the tabs on, but never used it. SOLD was $20 shipped
Factory Dana 60 tie rod SOLD $35 shipped (picture below)
3/4" between. They are setup for the rod ends on the PSC cylinders.
I'll take the factory 60 tie rod if you still have it.
PM me if you do.
