75 k5 blazer. Installing a New Vintage gauge cluster. A few weeks ago before I got the gauges I started identifying all the wires at the main plug. I very clearly had two accessory power wires at pins 5 and 12 that worked just fine. fast-forward a few weeks when I went to start to install the gauges I no longer had accessory power from the very start. To clarify, I didn’t lose power after I started splicing into other wires, right when I sat down to start the project the accessory power was gone. I started doing everything else thinking I would figure out the accessory power at the very end, and that’s where I’m at now. Everything is completely hooked up ready to go, and I suppose I can get accessory power from somewhere else but it’s bothering me that all the other wires to that main factory plug work except for that. I checked all the fuses and obvious stuff, but nothing seems to have changed or is blown. Any ideas?
