cabledawg
Secret Squirrel
Hey guys, waiting on my Ranger OD to show up, but in the meantime, I'm looking into other shifter options for the OD box. I want to avoid using two sticks and instead have the 465 shifter with an electric center off switch mounted on it. One direction will be for OD and the other for 1:1. I found some pneumatic cylinders and I have an on-demand air pump that should be pushing 100 psi, just not alot of volume. The switch will actuate the pump and open one soleniod (A or B) valve moving the cylinder in one direction or the other for the shifts. The cylinder will be mounted to the side of the 465 by means of homemade bracket.
What i would like is if anyone sees an issue with this setup ( if the attached pic doesnt work, try to use your imagination) and if something is wrong, what are the solutions. Originally I was going to use a cable operated push/pull button onthe stick, but I know that setup wont have the leverage nor the travel to make the shifts. So I came up with this setup.
