88k5blazin
i gotta raptor 350 that wont start. my buddy has one to so ive tried swapping the coil, mini computer, and stuff like that. check all the fuses and wiring and cant find anything obvious. it cranks and cranks but wont fire. i can empty fuel from the bottom of the carb after i crank for a while so i know its getting fuel and when i spray ether in there it doesn't make a sputter. i tried arcing the spark plug to the a arm. is that a good ground? im running out of idea. i'll apologize in advance if this posted in the wrong section or shouldn't be here
