Raptor Bed Liner
I know a bunch of guys have been using Extreeme Liner with good results. Check out Deulings build thread to see some pics of it. I think that is the route that I am going to go this summer. Its roughly the same price.
I appreciate the input, may have to look into that as well.
The Liner Extreeme seems to be some good stuuf. Just spayed it so no long term but it has a hardener and comes with a total of 3 gallons when all mixed so i find the $150 + shipping is worth it compared to other bedliners. The website is sprayonbedliners.info call the number and talk to laura for ordering:thumb:
I have used AL's liner on a few different applications now, and have nothing but good stuff to say about it. I sprayed the underside of my K5 with it, the underside off my dads 53 Willys wagon (both will get the insides sprayed when the time comes) and I even shot 2 of our gang boxes that go out on demo jobs with it. It has held up great and sprayed nice on all of the projects I've used it on, I highly recommend it :waytogo:
I've used Raptor on the inside of my K5 cab, inside of front fenders, and in the bed of my old tundra. I would suggest other options, as it looks really good when it's fresh, but it's not nearly as durable as something like Line-X. I will be re-coating the cab of my K5 with Line-X in the near future - Raptor may look good for a while, but if you're going to go to the trouble of doing it, it's worth it to use something that's going to last for a few extra bucks. On a positive note, I can say that it is very easy to make it look good with what's provided in the kit. It's some nasty ****, so make sure to use a good respirator when spraying it if you decide to go that route.
I 2nd the spraying and using a good respirator with cartridges rated for fumes. I took my resp off after spraying and it was hard to breath. Some stanky stuff. Definately try to spray if you can, it just looks soooo much better than roll on.
