goathearder
Hey All,
I took the top off my blazer for the first time last night and its awesome! I can't believe I hadn't done it before!
In doing that, it has actually exposed some things that I didn't notice before, the most annoying of which is that my doors are rattling like crazy.
I did some quick investigation and it looks like the door latch may be loose. Basically, from what I can tell, the door latch hits the stiker on the body just fine and moves into the locked position however when it gets to that locked position, there is a good 10 to 15 degrees of rotational movement in the latch. IE the latch is locking, but not locking solid. This rotational movement is allowing the door to move in and out a bit and causing the rattling.
Does anyone know if that latch can be adjusted to be more solid and take that play out of it? If it can, how do you do it?
Thanks,
John
Thanks,
John
