Re-clamp leaf springs?
Irish1941
los angeles
Seems the both front and rear spring clamps worked themselves loose and spread out.
Had a clunking coming from right under my feet when I was turning left or right. Searched entire front end but it was all tight. Then had a pal move the wheel and bingo! 2nd leaf was walking around in the pack.
Anybody got easy way to cinch 'em up again without taking leaf pack out?
well from working in a spring shop and seeing stuff you got more than loose leaf going on.
you need to pull ubolts and drop axle a bit . then check centerpin and replace if needed. next fix the clamps to stay tight.
but biggest thing is u-bolts are loose as the leafs should not fan out like that.
and u-bolts are to be used 1 time only also for best results.
Hmm...
I used new u-bolts, center bolts when I rebuilt front end 2 months ago but had a nasty PS leak that I since fixed. Coated everything in fluid. Did re torque
u-bolts but maybe time to have another look and tighten up center bolt.
Ever use these quick clamps for replacing clamps?
i use to work in a spring shop. thats why i say dont use them basicly in funny way.
thay deform real easy move around and dont do much other than look good for the first few weeks.
band aid for other problems tho . need to pin point first.
i almost lost a dana 60 with 38" tires 1 time on highway from front end problem i didnt know i had till almost to late.
let him take pics and post and we get that fixed then :dunno: about clamps.
