Re gear advise
mrgoodwrench
Minnesota
20200903_102744.jpg 20200903_102729.jpg So after procrastinating most of the summer im finally getting to regearing my front dana 60 to match my rear i did earlier this summer. here is my pattern so far any pointers? Im thinking it may be to close / deep or too far to the root and toe but wanted some input before i make more adjustments. Its a dana 60 front and currently has between 7 and 8 thou back lash and pinion bearing preload is about 17inlbs with no seal installed and one old race installed on the pinnion. Thanks for any input mike
That's what I was thinking I'm going to move opinion out A little and retry thanks for your response Mike
Final check with new bearings and such. Ive got 6 thou back lash spec says 4-9 so good there pinion bearing preload is 32in lbs spec says 20-40 i think its good to run but here is the final pattern ( hopefully) looks with new bearings like it may be a tiny bit more twords to but i think it good?
Also my gear compund is running lower and drier so that could be some of the change
I agree. It looks pretty good, it’s still centered pretty well.
No big deal really if it’s not perfect, it’ll wear in. :D
