In a month or so, I plan on doing an axle swap, re-gearing, and locker.
I have 33" tires and no lift. I have zero plans on lifting or going to a bigger tire. I am happy where the height is and my K5 does well wheeling.
So for axles, I plan on keeping the front 10 bolt and adding a Lock-Right. For the rear, I am plan on going with a 14 bolt semi-float, 6 lug. Shockingly, Lock-Right's are $400!
Detroit's are in the $550-600 range. So I think I'll stay open, for now at least.
So have two questions.
I am leaning toward going with Yukon 4.11s. Is that too much gear? Not enough? I will be driving my rig to any wheeling events as well. Also, I prefer trails, mud, and some rock play.
Also, will I need any additional items for the linkage of rear driveshaft to the rear end?
Detroit's are in the $550-600 range. So I think I'll stay open, for now at least.So have two questions.
