Obviously you guys are just jealous. Aren't any of you guys running a 258? None of you swapped out your 14 bolt for a AMC 20? What are you thinking? Hmmmm..... If you want a good J##p, here is the recipe. Buy one good J##p tub, throw away rest. Then purchase one Chevy (may be completely rusted out), one Ford (anything not running will do). Now take the motor (preferably a nice 350 but a big 454 will also suffice). This is where you might want to experiment with different tastes, use 700R4 or 465 from GM, or 435 from Ford. Take 205 from either. Use the reverse cut 44 for the front out of the ford and perhaps the 9" for the rear. Throw rest of ford out. If Bold and spicy is your kind discard 9" and 44 for Dana 60 and 14 bolt. Now you may bolt the glass body on either frame, trimming where necessary. Serves 2 passengers and not much trunk space.
Seriously though, a ford or chevy filled jeep is a lot more maneuverable than a Blazer, just a fact. Wheelbase sometimes helps, off camber is much more stable in the K5, and have you ridden in a TJ lately? Whoa! Pretty comfy! Take care guys... Todd
"You're right... I don't understand that Jeep thing!"
