sloanstavern
Newbie
Afternoon, and Merry Christmas
Very nice site you have here, I have just picked up an 85 K5 that my son and I are working one, and have a timing issue that has me scratching my head, and before I burn any more BTU’s thought I would float this for my first post. I did a search and could not find the solution.
It was running great when we bought it, but failed the first time through emissions, for CO. I rebuilt he carb, because it had some horrific leaks, and the test confirmed the rich condition. I also tried timing it and then is when the troubles arose. I now fly through CO but fail NOX and this may be due to poor / incorrect timing. Since that is the only knob I turned, I want to get it fixed before I try anything else.
I have a stock 85 with 5.7 and CA emissions my timing sticker is toast, but I found one on line and it calls for unplugging the 4 wire quick connect off the distributor then timing to 6 deg BTDC. Problem is there was no timing tab on the normal driver side about 2 o’clock. I hooked up the timing light and no matter how I twisted the distributor, I did not see the mark on the balancer at all.
Today I pulled #1 plug, brought it to TDC and the mark was visible on drivers side about 2’oclock right where I would expect it. I opened the distributor and the rotor was off ~ 40 degrees ( if it was 180 Off I would have known I was on exhaust, but 40 off???).
Put everything back together, then tried shining the timing light on the passenger side and saw the mark on the balancer, but no tab.
I am lost, do you guys have any idea what the heck might be going on?
