Metalhead47
So I finally got my knuckles off... and the lower ball joints are STILL fused to the axle housing C's. Tried hammers, tried heating with a propane torch then dousing with Freeze-off, air hammer, PB blaster, pipe wrench, even the trick with the nut, bolt, & socket to try and press them out, something started to move and it wasn't the ball joint so I stopped there. I do NOT need to crack the inner C and go thru this all over again with a new axle!
I've tried everything short of an actual ball joint press at this point, but I honestly doing think that's going to work, seeing as how the joint is stuck in the wrong piece. Guess these things should have been replaced sometime in the last 220k miles
Any other idears here or is this the point where I just lug the housing down to the machine shop & have them figure it out?
