79rustyk10
3/4 ton status
Cant get this POS to run right, has had a terrible off idle stumble since the swap 5 years ago, I can floor it, and it will pop and run on a cylinder or two for a while and it might eventually take off. runs OK at WOT if it can it there. Its borderline immobile.
Didnt have vss hooked up at first, but got that taken care of with no change
Replaced TPS, no change.
Overhauled the throttle body, newer injectors since the ones in it had large amounts of rust and scale in the little screens. added the CFM tech adapter and pressure gauge. has 12 PSI at idle, good spray pattern from the injectors. It starts right up better than before, but if I snap the throttle open it stumbles like normal.
Theres also no CE light for any of this. All I can think now is that its an ignition issue.
I havent had a scanner on it yet. Thats the next step.
Any ideas?
Any ideas?
