I've got a 76 k5 with an 82c10 body and trying to get my guadrajet electric choke wired up. I have no wire under the hood for the choke and my oil temp sensor is only 1 wire so I tried the wiper motor and have power even with the key out of the ignition dunno what's going on there... But I do have an open connection next to the brake booster that I believe was part of the evap canister that's no longer installed it has 1 blue and 2 green wires going to it and has an unused vacuum line since this is working on key on power do I just use this? I had bought a tap a fuse I was gonna tap into the choke fuse in the panel but realized tap a fuses are only good for 10 amps and believe I gotta stick with the 20 that it was originally set up for
