Rear axle question!
mostly on 14ff rear to get the massive slop.
cause its a moving locker inside a carrier . not just the locker alone . little more moving parts basicly.
drive one with a stick shift than can be fun till you get use to it with banging and poping under load with the play on the 14ff rear.
Damn!! I fixed the drive shaft then i went to test it, while doing a turn i heard a voise like somthing broked and shacked the blazer! Is that a detroit locker noise!!!!!!??????
