Alright guys, my continual slow upgrades are progressing.
I have a rear axle from a 2004 Silverado on the way, it's going in my 88 Suburban. I'd like some confirmation on the spring mounts.
Everything I've read says the NBS spring pads are 49" apart, and the 1/2 ton square chevys are 42.5 inches apart.
The '88 rear should be 64' at the wheel, and the '04 should be 68" which should put my wheels perfectly spaced out.
Can you guys confirm that info?
If it's correct I just need a set of spring pads 3.25 inches in from the 04's and I'm good to go. The axle is coming COMPLETE, even the emergency brake cables with forward mount.
