Groz's Burb
Registered Member
Hi y'all,
Haven't been able to find much info on this, but my driver-side rear barn door will not budge. The release-latch seems like it gave up.
I can open my passenger side.
The latch (toward the bottom) on the inside of the stuck door that you normally pop 'up' to open is stuck in the up position.
Is there a certain way to release/ open the door so I can inspect or replace the latch?
Start with removing the inner panel I assume, any suggestions from there?
Thank you in advance
MJG
MJG
