dudeiwin86
Registered Member
Sorry for the newbish question, but i did search, and all of the results i found were for a 14-bolt and im not sure if its the same as my 10-bolt.
i have steel hardlines from the distribution block (sitting ontop the diff) going to each brake drum in the rear.
the way they were routed (by the previous owner?) caused them to rub and i actually wore a HOLE into one of the rear steel brake lines (yes. a hole in a hard line... )
what is the thread size on the distribution block and brake drums?
does the steel line size really matter?
O'Reilys is showing 3/16" O.D. lines, 1/4" OD lines, and all sort of options for threading.
i dont know what to make of it and i was trying to avoid tearing it down until i had parts in hand to replace.
thank you!
thank you!
