Ok guys so I'm geussing that ever since I got my 76 k5 running the rear brakes have not been working. I just noticed it though a few weeks ago when I was backing my little 400 pound utility trailer down my fairly steep driveway, I was going maybe 3 mph and then hit the brakes and skidded about 4 ft backwards before stopping. Also I had some wet leaves in front of my house (flat ground) and when I would pull up to the curb where I park I could be going 5 mph and skid through the leaves. And more hints to the rears not working is the brakes just being generally a little soft and this truck surely will not stop on a dime if I slam the pedal down. I should have posted this sooner but I forgot to, anyway I've got some time tomorrow morning and would like to try to get them working, any ideas? I did bleed the brakes about a month ago when I put in a new master cylinder and there IS fluid getting to the rears. I think they need to be tightened. How do I go about this? Is there a bolt or a spring tensioner or something? If it matters its a 76 with a 12 bolt 6 lug rearend. Thanks a lot yall.
