BlazingBlue305
Registered Member
Hey yall, I just replaced the whole brake system on my ‘81 Blazer. Went to bleed the brakes and found the rears have no pressure. I can only get small drops of fluid. Brake pedal will only build slight pressure up to a certain point. The proportioning valve is new so I don’t think it’s that. I believe it has something with the new master cylinder? I bled it in the vehicle and did notice the port for the rear wasnt putting out as much fluid as the front. I know that’s somewhat normal, but this was a big difference in fluid. Any ideas why pressure to the rear is restricted? Thanks in advance for any input.
