So I am now looking at replacing body mounts. The guy I purchase the truck from has replace all body mounts except (2) for some reason. The two that have not been replace are just ahead of the rear axle. Looks like there is a old rust thread piece hang down and some what of a rubber mount up there.
I will try and post pics when I get home.
The question I have is how do i go about replacing these two mounts. Do I need to remove the carpet in the back area to gain access to the bolts? or are these treaded up from the bottom into a pocket? How do you lift the structure to install the new mounts. It seem odd that these are the only two not replace.....So I am assume there must be a reason....
