So winter is apon us and the rear defrost issue is back. After extensive research I have found this web site: frostfighter.com they sell this kit...
"Clear View Defroster Kits
Complete Defroster/Defogger Kits. The Frost Fighter Clear View Kits have everything you need to install a high quality defroster that melts snow and ice plus clears mist instantly. Clear View Kits provide full rear window coverage with an attractive factory look. The thin, dark brown grid lines come on pre-spaced rolls for easy installation. This kits is complete, with full instructions, pre-assembled wiring and electronic timing switch that make it easy to install. Available in three sizes. $45.95"
I plan on installing this kit and then tinting over it, hopefully this will prevent the kit from being detroyed when it goes up and down in the tailgate. I have also talked to every GM dealership in CT and they all say no Suburban window w/ defrost will ever fit in a K5, they used different size glass. Does anyone know if thats true?
Has anyone attempted this or anything like it? As soon as the project is complete I will post pictures.
The Rooster
The Rooster
