Just like the title says, my rear differential is leaking. I have a few hours tomorrow morning and I think I can tackle this. Like most of you know, I'm learning as I go here. I have never removed a differential cover, drained one, resealed one or refilled one. I was under the truck yesterday and snapped some pics. Where do I start? Where do you actually fill it back up? What should I use to reseal? Gasket? What oil and how much?
I'll admit that I'm embarrassed that I don't know what seems to be an easy fix. I'm just tired of seeing this on my drive way.
I'm thinking that plug has something to do with the refill portion? If so, is a special socket wrench needed to remove? Does it have a seal or o-ring that would probably need replacing?
I would just get the correct FellPro gasket and some Black RTV. Let it set up and you should be good to go
