Rear Disc brake conversion
Yes, the parking brake is a problem. I have the adjuster tool and did the procedure that I believe was correct. I know that 4:56 gears with a big block and 700R4 pull decently off idle, but I had the drums before, so I had a frame of reference. And I don't use the park brake much with an automatic transmission either, but I wanted it to be functional if I needed it. As it is, I just use it to keep the calipers adjusted.
I think the kits and how they adapt a caliper is nice. The packages tend to be complete and without issue. Steer clean of the caliper brackets that use spacers. I don’t remember where mine is from, maybe DIY4x, but his brackets have a bend in them which worked out much better than the included spacer/brackets that came in a kit I bought from xyz brand originally.
I will be adding the JB Conversion parking brake kit that mounts to the 241. I hope is clamps better than the calipers do.
Again, I don’t have much of a gripe about the parking brake, I knew I would be loosing it. It’s the spongy feel and terrible “holding power” while in 4L. (700/241/4.88/37”)
If you really really want to ditch the 12b and gain disc brakes, you’ll be MILES ahead just swapping a newer axle in with disc already.
Hey Chris,
I agree with the guys that say leave it alone. Based on our conversations, I don't think you are going to lack braking power for how you plan on using it. I'd put it all together, start using it, and if you decide to change it up later, you can do it then. Properly adjusted drum brakes for the rear should work just fine.
for the Cadillac parking brake to work properly it has to set each time you park you vehicle. The parking brake being set adjusts the caliper out to the rotor to maintain proper braking.
I have the Cadillac caliper kit from Lugnut4x4. They work decent but require a lot of fine tuning. Lugnut4x4 had great customer service and the parts provided are good quality. I would not hesitate to buy from him again.
That said, stay drums or swap a newer rear axle like others here have posted. The Cadillac calipers work ”meh” at best as a parking brake.
I have a brand new set of brackets from Little Shop mfg. for sale. Only reason selling is I’m going with a 14 bolt. 150 shipped
I may be interested. where can I get information on this kit and how it works and what does it fit
