I put a 14 bolt under my K5 a while back and upgraded to rear disc's.
It was originally a diesel (civi) from the factory and still has the factory hydra-boost.
I've bled the brakes both manually and with my pressure bleeder.
So I'm very confident that air is not my problem.
But, I can't get enuff fluid pressure to the rear. When you mash the brake pedal, there's way too much travel in the pedal.
Could it be the equalizer ??
Under normal driving/stopping it feels like the rears are not even getting pressure. I've done this swap several times to my other trucks without any problems. WTH ???
