rear driveshaft angle
jester
Prineville, OR
The Jimmy I aquired had a 4 inch lift put in it and I have been breaking U-joints on the rear driveshaft. I was told it is because my driveshaft angle is off and was not compensated (spelling?) for when they put the lift in. I was going to put some shims in it to make it the right angle, but what angle is it supposed to be at? Thanks!
I'm not sure what the normal operating angle is for a stock u-joint (though I'm sure there's a number floating around somewhere) ... but you're having trouble w/ only 4" of lift????
Maybe you could lower the t-case and use a degree shim to tilt the pinion up a little bit (if you have done this already)
i assume you have just two u joints /forums/images/graemlins/dunno.gif
you have to run them within 3* maby 4*if you had to
the trick is to get both u joints at oppisite angles
so if you have 2 down on the top make the bottom 2 up or whatever the angle works out to be /forums/images/graemlins/waytogo.gif
do you get alot of vibration while driving /forums/images/graemlins/dunno.gif
also might be a idea to get the driveshaft balanced /forums/images/graemlins/waytogo.gif
