Rear driveshaft, Yoke or Flange?
Taylor
Elizabeth, CO
I'm swapping out my 700/208, for a 400/205 combo. I just finished rebuilding the 205, and converted it from a slip to a fixed yoke with a kit from JB conversions. I got a kit with a 1410 yoke but I'm wondering if it would be better to go with a flange instead of the yoke so I could run a CV driveshaft? Were do you draw the line between a u-joint-to-u-joint shaft and a CV, is it all about the angle? I'm at 13 now with my 208 and one of HAD CV slip yoke shafts, so I should be in the 10 ballpark after the 205 swap. What do you think?
U-joints run at angles will vibrate. If you look at one cap, it will speed up and slow down as the shaft rotates.
If you set the operating angle between the t-case output and driveshaft equal to the the operating angle between the pinion and driveshaft the vibrations of the two u-joints will cancel out and you won't feel any vibration from the shaft. That is, in theory...
In the four wheeling world, that doesn't work that well. IIRC Spicer said the operating angle on its joints should be under 3 degrees to insure no vibration.
Most of you running lifted trucks have at least 10 degrees at each joint.
The theory is that if you run the same operating angle at the t-case joint and the pinion joint that you will have no vibrations. In the real world that is not the case, because you are exceeding the angle limitations of that setup (not binding, just from a vibration standpoint).
Some people can make it work and get little/no vibration on a lifted truck.
I would say that with more than 4" of lift you have basically no chance of having no vibrations without a CV shaft.
You have a pickup with a pretty long rear shaft, and 10 deg. isn't very much IMO. I bet you would be okay with a standard driveshaft, but a CV driveshaft would eliminate all doubt and would run smooth.
I know that I typed a lot of info here, but I would probably run a standard (non-cv) shaft if I was you.
icehouse said:
Matt,
Here is some good reading for you http://www.pirate4x4.com/tech/billavista/PR-shaft/index2.html
I think I remember hearing that 8 to 12 degrees was about the limit for vibration free operation at highway speeds with the single joint setup. I would probably call a few driveshaft shops and get there opinions.
Good article...Thanks for linking to that.
I'd run what you've got, 1410's run pretty damn steep.. or step up to the next trend and go 1480 before it becomes normal and make sure you add it in your sig so we are all jealous :D
