Rear Driveshaft
Emmettology 101
3/4 ton status
PA
How much longer will a SWB p/u rear driveshaft be than a K5/Jimmy rear shaft?
I know the K5 WB is 106.5 and the SWB P/u is around 112. So is there a total of 6inches difference in the shaft?
i am getting a SWB p/u rear shaft since I broke my slip yoke and I needed a longer shaft anyhow. I figured if it is too long it is cheaper to have it shortened than to have mine lengthened.
But it would be nice since my truck has a 6" lift on it if the shaft needed no modifying at all!
( I know that adding a 6" lift isn't going to require 6 more inches in the shaft, but I was just letting you know that my K5 isn't stock)
Thanks
Mike
See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
you want to make your shaft catch up with the reast of your rig let me know- we can go to 1410 if you want- jess
My rear driveshaft on the K10 is 42", the K5 is now 36". Doesn't it depend on alot of variables- ie. tranny type, lift, t-case, pinion angles, etc.? But my guess is it's way too long... $.02
<font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
:) I would like to do that now, but the little woman and the cash flow says no! When the time comes, you will be the man i call! I really like the looks of that 1 ton 32 degree front shaft! I would like to get one of those and a CV rear shaft with Slip joint and a NP208 fixed yoke kit(maybe just Dodge parts)
But for now, I will have to settle for stock type parts. :(
Mike
