My driver's side rear brake drum is pretty tough to get on and off, and it drags.
The adjuster is all the way in. It's visibly more expanded than the passenger side.
The only thing I noticed is this... the parking brake strut (the metal bar between the two shoes) is the SAME exact part for both sides. There's a bent up lip on it, and because the two ends of the strut are different, I installed it facing the same direction on both wheels.
That means that the "lip" is bent upward on one side, and down on the other.
I hope that makes sense. This is driving me nuts...
Also, the rubber hose that leads down to the "T" fitting on the axle... that hose's connection is stuck in place. I previously cut off the bottom half of that hose, so there's no reusing it. I've PB Blasted the fitting, and so I'm waiting...
I need these issues fixes ASAP!
TIA for any advice...
