1991 Suburban 3/4 ton, 14 bolt semi-float rear-end, mild-ish 383", 285/75/16 tires (32.84"), stock 3.73 gears, 4L80e trans
My rear pinion sheered a few teeth. It is currently in a shop being rebuilt. I am going with a Truetrac diff and deciding on the gear ratio.
In SoCal, I freeway speeds are typically 75+ (80 at times). I don't go off-road much, but the occasional trails - nothing hard core. I do tow a 5,000lb boat occasionally.
Just looking for guidance: While the rear is being worked on, do I change to a 4.10 gear ratio - then I will have to re-gear the front end ($1,000+ gears, seals, etc) to match, or do I live with the 3.73? I don't plan to run larger tires - 33" tops if anything. Will I notice much difference between the 3.73 and the 4.10? I have always felt like it could use a bit more, but just don't know if the cost is justified.
Carnage shot:
Carnage shot:
who does them for members .
