78Suburban
I installed an echobit shackle filp and netted around 5.5" of lift in the rear of my burb. I've bent the little metal bracket that connects the hard line in running down the chassis to the rubber line. Bending the bracket may have given me 1" more play in the line back there. When I dropped my rear axle with the tires removed to install my shims, the rubber brake line stretched out like nothing I've every seen. Hopefully its still air tight.
I'm not worried about the brake line length flexing, but When both tires drop from hitting a big bump, is my stock line gonna rip off?
Who all with a rear shackle flip or 5" lift has their stock rear rubber brake line? Had any problems with it? Who has used an extended line back there, and what is the part number? Where did you get it and will it work with my 14ff.
Sorry for assaulting yall with so many noob questions, but If I do need an extended rear line, I wanna get it before I bleed by brake system.
thanks,
James
thanks,
James
