Ok, so how does the rear heat system work? My lines have been cut front/rear, and i want to put a new core in, fix the lines, and try and hook the rear heat back up.
Rear air works, so blower should be good. Nothing happens when rear heat switch is flipped, im guessing someone disconnected it.
So is there a heater valve or somethign for the rear? How does it switch the blower to blow over teh heater core?
Any other tricky (expensive) parts, or jsut the core?
