I've used a multitude of different methods to get those spring bolts out,all are rather hazardous and involve sparks,hot bits of metal,and usually at least some blood will spill before they are out..
I have used a sawsall with Lenox "fire & rescue" blades,those usually work well,but often get bent in half when they snag between the spring and bushing and the hanger...
I have also used a 7-1/4" meat cut off wheel intended for a circular saw on my 9" grinder,with no gaurd--highly dangerous,but effective..the one time I got wounded using this setup was when I sawed the bolt and when it got almost all the way through,the spring decided to twist when the bolt broke free and clamp the disc between the bushing and hangar and it blew apart in about 1000 pieces,some of which stuck in my arm,and barely missed my eyes--my left wrist also got slammed against the spring when the grinder went from 6,000 rpms to zero in 1 millisecond...
I've had little success using an air impact gun on these bolts,the bolt often seizes to the steel sleeve in the bushing and the impacts are all but absorbed by the rubber,and it'll just laugh at you--using a breaker bar & cheater pipe is what usually gets the bolt loose,if it'll ever turn at all--I've torn the rubber out of the bushings torquing on the bolts that way..sometimes the bolt will loosen once it is free of the rubber,but you'll still have a battle getting the sleeve of the bushing off it so it can be slid out of the hanger...
Torch is very risky,being so close to the gas tank,and the rubber in the bushing will burn a long time unless you have a hose handy..
One truck we had at the junkyard ,a Dodge,had the leaf spring bolt in the forward rear hanger seize that way,and the bolt was installed with the head side facing the frame ,and it would have hit the frame before you could get it out far enough to remove the bolt!...after battling with it for an hour ,unable to use fire or saws,we decided to cut the spring hanger,got the bolt out after the spring was off,and welded the pieces back onto the hanger!..
One trick that has worked for me a few times is to remove the nut on the bolt,stack some washers under it,then cut off the head of the bolt with a sawsall,grind it a little ,then use an air impact to tighten the nut--this sometimes pulls the bolt through the bushing sleeve enough to break the rust bond,then it'll spin out or you can punch it out with a drift..
Leaf springs are among the "worst" jobs to do on a truck in my opinion..most salvage yards here will cut off the rivets to the spring hanger off the frame,and include the hanger with the springs now,a bonus because most of the time your is rotted and needs replacing anyways,and for some reason the junkyard trucks usually have minty looking hangers...its not much fun busting rivets on your truck and having to drill the holes larger and use bolts to re-assemble everything,but I think that it is easier than dealing with shackle bolts..
