Yes, there is one 3.5" rancho block on either rear side in back,then on the drivers side ther is also a 1" block shaped the same as the rancho 3.5" block( concave corners). This was how a Bronco I had once was also. It was said it compensates for drivers weight and equiptment on the drivers side. I can buy this somewhat as the drivers side spring pack or rate is often different but when its using the stock leaf pack in back??
Regarding over flexing the pack without the bottom helper I dunno, Ive had our 74 loaded shortbed loaded with 20 bales of hay and the axle was hitting on the rubber snubber,the big helper stayed pretty flat and all the spring flex was out at then ends which IMO would really stress the outer parts. Then looking at almost all aftermarket rear packs they use no thick flat spring in the bottom makes me thinks it might work fine,just can load it up much.
