Rear Load Adjusting Prop Valve
ARAMP1
Aviator Extraordinaire
Memphis, TN
Anyone know anything about these? (I searched and couldn't find anything using the search) Mine's not working too well (don't even know if it ever was working right after the lift was installed) and I couldn't find a replacement from LMC, so right now, all the arms/levers are off and I'm probably just going to bypass the whole valve eventually. Anyone ever done this before?
Just bypass it like you want. It won't hurt anythng. That valve just changed the brake bias when weight is added in/behind the rig.
Right, but I'd guess that when there's a heavy load, the valve lets more fluid in for more pressure. By bypassing the valve, wouldn't it be like having the bed of the truck loaded down (without the weight)?
The valve actually reduces pressure to the rear with the more weight you add.
