My dad finally listened and will let me put a locker in his farm truck. It is a 2001 HD2500 with a 8100. What lockers are avalible and what are the installation requirements? A 14FF is easy but I am afraid this will be much harder.
It pulls a 26,000lbs trailer most of the time.
It could use a lsd but I was just going locker since swapping a carrier is swapping a carrier. Dodge is the same, wonder if I can find a used dodge carrier. ARB is too much trouble and expensive and the Yuckon is the only other locker I see. A truetrac is ok but I have seen a few exploded.
Sounds like your dad has been right all along.
You want to put a true locker in a rig that tows heavy on a regular basis?
If it's got the G80, I'd leave it alone. If not, I'd go with the Dodge limited slip, I can pitch my 06 Mega Cab Cummins side ways if I want to, it works just fine.
I would never put a full on locker in a rear end that tows all the time.
