Blazin'4x4
Anyone have any tricks to replacing the oil pan gaskets while the engine still in?
How would I tell which is leaking between the two? If I let my truck idle, I would lose a quart every ten minutes.
Thats awesome though thats exactly what I was lookin for. thanks.
my head gaskets went and i was like eh might as well do it all so im not back at it in a couple of monthsI wish I could just pull the motor out. Then I know I would end up rebuilding it, then the tranny, t-case, then why not a frame off resto.........Just to make my engine quit leaking.
i did exactly that. my head gaskets started leaking and i said ahh what the heck i will just re seal the entire motor
next thing i know im trying to swap in a nv4500 re seal it and possibly rebuild it
now my baby has been sitting for 4 months and its the summer season and no fun for me
should have left it in and did the head gaskets in frame.sounds like the rear crank seal...
to remove the oil pan,,unbolt the motor mount bolts,, lift the front of the engine and the pan will clear for removal.
to remove the rear crank seal,,drop the oil pump, unbolt the rear main and remove,,,1/2 of the seal will be in the cap,,the other 1/2 will be in the block.
the one in the block can be pulled out with needle nose pliers,
CAREFULLY,,don't gouge up the crank journal...
the new one will need to be rolled into place,,use a little permatex
not silicone,,on the backside of the seal,make ssure the lip faces the same way as the old one !!!! ,roll the crank over as you push the new one into place, if needed. oil the seal and crank good after it is in place.
change out the seal 1/2 in the cap,,,Lube up the bearing and seal
and torque it down.
install the pump and pan,,bolt down the motor mount bolts and your done.
