I didn't realize this until I saw it in print one day, and while my experience is maybe 10 among millions, any double lip seal surface I've ever dealt with was on the dust side of the seal, not the oil side. I still speedi-sleeve them, but that was before I realized I was never seeing two grooves.
The picture shown is a solid front axle truck, so IFS isn't a factor, nor is vertical clearance. IF there is nothing to keep the pan from dropping straight down, there is plenty of clearance to drop the pan on a squarebody 4WD. Looks to me like it's super easy:
Not to get into a pissing contest, but every Chev small block installed factory since 1987(?) until the end of production used a one piece rear main. I find it exceptionally hard to believe those are more problematic than the two piece seals in service. My only "personal" experience with them were my buddies 1990 Suburban and my other buddies 1995 3/4 ton both with 100K+ on the odometers. Neither leak a drop from the rear main. I've only had my L31 crate in for about five years, and it rarely gets driven, so I'd not use it as an example of long term success.
hope the pissing match/ hard to believe part wasnt about my posts- fully agree its way better than the 2 piece... I was only saying that on all the one piece seals I've had leak? they all had grooves worn into the seal surface, and simply replacing the seal itself was not a long term fix.
what was that first part about double seals and dusty groove stuff? I think i read that and understand it as you have found grooves, but usually only on the outer part of the seal?
-edit- and yes, the only pan Ive pulled off while engine still in the truck was a stock height 4x4 1989 Burb. -no wait, I also pulled the pan on my K5 when the I sheared the bolt on the main cap. But the K5 was lifted. That made it easier. In both cases, there was something wrong with the engine and I was not trying to seal a leak - I just needed to get eyes on all the fun parts.
From what I remember about My 1990 2WD suburban, and My buddy's 1997 Z71 with the IFS 4x4 -the crossmembers are bigger and wider than on the square body 4x4, closer to the oil pan, and there is a lot of other parts getting in the way of both Tools getting to the pan bolts, and also looked like there wouldn't be enough room to drop the pan and get it out.
