patrickgraven
Registered Member
I have a 91' Suburban with the 241 transfercase. When I was replacing my rear u joint I noticed it was leaking around the rear output on the transfer case. So I picked up a new seal but have not installed it yet. Is it easy to do? Do I just remove the old one and install the new one? Is there anything else preventative I should do while Im doing the seal. Thanks in advance.
