Rear output shaft seal leaking np208?
badmix
West Virginia
Rear output shaft seal leaking on transfer case, when I go to Rockauto, they list seals with sleeves and diff size sleeves at that. Not sure what to order ?
The sleeves with the seals are a repair kit if there has been a groove worn in your output shaft / slip yoke.
Pop out your slip yoke and take a look.
Prop want to replace the yoke bushing in the tail housing as well if it wobbly, no seal will stop the drip.
Be sure to check your breather tube make sure it is clear.
And that it’s not overfilled. I think you can get a seal from a newer np241 as well and it will have a double lip. I’ll try and find the part number on the one I got.
